Arbortech Ball Gouge
- Quickly and easily carve smooth hollows
- Attaches to standard 100mm or 115mm angle grinder
- Carves in any direction, easily hollows or undercuts
- Create beautiful chiselled textures on wooden surfaces
Revolutionising the way you carve!
With this innovative cutting tool, you can hollow out, create smooth concave shapes, sculpt freehand and add chiselled texture to your woodworking projects!
Undercutting and hollowing out
Ideal for carving smooth hollows in wooden spoons and creating concave features for bowls and other small to medium projects.
Texturing
Not only is the spherical shape perfect for multi-directional freehand shaping, but it also makes it ideal for achieving a range of different textures.
Freeform sculpting
Carve in any direction without compromising on control. Quickly achieve concave surfaces in spoons and small bowls and finish off projects with beautiful chiselled textures.
Control and balance
Engineered to provide exceptional control, balance, and performance. It has anti-grab technology which helps prevent the tool from digging, so you have better control over the look and finish of your woodworking project.
Long lasting design
The Ball Gouge has a revolutionary, ring shaped blade that is self sharpening, rotatable and replaceable providing optimal value and durability.
The Arbortech Ball Gouge is a unique tool designed for power carving. It has a cutting ring on a 30mm spherical ball with a 90mm arm that attaches to the Arbortech Power Carving Unit or any standard 100mm (4") or 115mm (4.1/2") angle grinder. The cutting action produces fine shavings rather than dust.
This ball gouge gives you the ability to make smooth hollows and concave recesses in spoons or small bowls and safely undertake freehand shaping and carving. It allows you to create an interesting, dimpled, chisel-like texture when moved across a wooden surface.
The perfectly engineered balance provides exceptional control and prevents dig-ins and grabbing. This offers greater control over the depth and final appearance of a project.
When in use the cutting ring is self-sharpening. While one side of the ring cuts, the opposite side of the ring is polished. By simply loosening and rotating the ring, you will achieve a freshly sharpened edge. The previously used edge then undergoes self-sharpening, more than doubling the life of the cutting ring.
Includes key for adjusting the cutter.
- Efficient and high performance tool offering exceptional control
- Anti-grab technology prevents tool from digging in
- Self-sharpening blade, rotatable and replaceable long life
- Max speed of 12,000 rpm
- Standard UK (1-2 days) - free
- Premium UK (next day) - from £10
