Easter Sale Now On
NOW ON!
Shop now
Axcaliber FineLine PTFE Coated Saws - Set of 3
717955
From £39.98 £33.32
In Stock
- get it Saturday 30th Mar, order within and choose Premium delivery. Delivery info
  • Triple diamond ground FineLine teeth, super sharp and long lasting
  • Rigid blade with low friction, rust resistant PTFE coating
  • Heavy duty soft grip comfort handle
  • 2 x 7tpi 500mm (20") & 1 x 11tpi, 500mm (20") length
  1. Axcaliber FineLine PTFE Coated Saws - Set of 3
Total:
£145.42 £121.18
Pull and push
Each tooth has three cutting edges. This tooth design produces a fast and very clean cut, both on the pull and the push stroke.
A saw for all seasons
The low friction PTFE coating not only protects the blade from corrosion, it also makes it glide through even wet timbers.
Staying sharp for longer
The technologically advanced diamond grinding process ensures a precise tooth form, with impulse hardening offering greater durability and longer life.
More than a saw
Fitted with a heavy duty two part comfort handle that incorporates 45° and 90° angles for fast marking out.
'Hardpoint' handsaws for timber & plastics
Package deal comprises the Axcaliber Fineline PTFE Coated Handsaw. Two with 7tpi and one with 11tpi, all are 500mm(20") in length.
These razor sharp, triple ground teeth cut with amazing speed. The blades are made from 1mm thick steel and given a low friction PTFE coating that also protects against corrosion. The teeth are electronically hardened and diamond ground. The saw is fitted with a heavy duty two part comfort handle that incorporates 45° and 90° angles.
5.00 2
