Axcaliber Flush Trim Cutters Top Bearing
From £20.88 £17.40
  • Perfect cutter for template routing
  • Bearing replaces need for guide bush
  • Bearing diameter same as cutter diameter
  • Greatly simplifies template making
  • Precision made cutters on multi axis CNC machines
  • High shear-cut angle for cleaner finish
  • PTFE coating helps minimise resin build-up
  • 1/4"(6.35mm) shanks
Assurance with Axcaliber
- see how they're made
These cutters have a bearing guide located on the shank, negating the need for a guide bush when following a template. The bearing is the exact same diameter as the cutter, simplifying the process when making a template. No calculations are necessary, as the workpiece will be an exact copy of the template.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
4.60 25
