PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
23.9% APR (variable)
Purchase interest rate
23.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
Vacuum pressing is the most effective way to clamp veneering work and light weight laminations, providing an even and massive clamping pressure over the whole surface. By extracting the air from the vacuum bag and creating a vacuum the full weight of atmospheric pressure bears down on the contents of the bag exerting an evenly distributed pressure of around 8.5 tons per m². This unit uses a 100% duty professional quality dry running vane pump giving 8m³ per hour developing 85% vacuum. A built in vacuum gauge give a visual indication of performance whilst a heavy duty foot switch gives convenient control. The extra large capacity 2,500 x 1,300mm heavy duty 300 micron seamless vacuum bag is supplied as standard and will accommodate almost any project. Up to 2 bags can be run from this pump simultaneously. If you are laminating with a vacuum press it is only necessary to provide a one piece former as the vacuum bag will provide an even pressure as it moulds the timber into the shape of the former. We can offer custom mould former manufacturing for you, utilising a CNC router for complete accuracy. Please contact our Commercial Sales Dept on 0845 0707870 for further details.
8m³ per hour professional vacuum press system
100% duty cycle dry running rotary vane pump
Built in vacuum gauge and heavy duty foot control switch
1,300 x 2,500mm, 300 micron seamless polyurethane bag
Lacquered birch ply protective frame with carrying handle
Ideal for single or dual bag veneering and laminating operations
3 years warranty against mechanical or material failure
This product is classified as a Dropship product. Dropship products are usually
readily available and despatched directly from the manufacturer using the best delivery service
available. Despatch times can vary between manufacturers and delays may occur should stock become
unavailable. Please contact
customer services
for more information.
