Co-Matic
Co-Matic M3 Baby Power Feed
SKU: 210133
€420,00
  • Perfect for small spindle moulder, router tables and surface planers
  • 3 PU rollers of 76 x 30mm give non-marking grip
  • Variable speed, 2 to 12m/min plus reverse
  • Unique 3D adjustable arm, with 150mm depth and 260mm reach
  • Light duty unit for the hobby and smaller trade user
  • Greatly aids safety on moulding operations
A lightweight power feed suitable for use on a small spindle moulder, router table or surface planer. Fitted with variable speed of 2-12m/min + reverse. The three non marking PU rollers are fitted with suspension movement for extra grip and to cope with surface irregularities. The arm is a patented 3D adjustable design for ease of use. The unit can be mounted directly onto the machine or fitted using the Co-Matic mounting base which simply clamps to the machine.
Feed Speed 2 m/min to 12 m/min (var)
Rating Trade/Professional
Motor Power 90 W
Web Attribute Set Power Feed Units
EAN Barcode 5052511006861
