Festool
Festool OF 1400 EBQ-Plus Router (1/2")
SKU: 333081
€755,00
  • Powerful smooth running 1400W motor
  • Precision depth adjustment and turret stop
  • Integrated dust extraction attachment with light module
  • Easily accessible variable speed control
  • Constant load monitoring, electronic brake and soft start
  • Supplied in SYS3 M 337 SYSTAINER case
The Festool OF 1400 EBQ-Plus Router is a professional-grade 1/2 plunge router designed for precision routing, edge profiling, grooving and jointing across hardwood, softwood and sheet materials. With a powerful 1400W motor, 70mm milling stroke and finely adjustable plunge mechanism, it delivers smooth cutting performance and excellent control for both workshop and on-site woodworking tasks. A key advantage of this compact router is its balance of power, low weight and efficient dust extraction, making it particularly suitable for detailed routing work where accuracy and visibility are essential.
The OF 1400 EBQ-Plus features a precise depth adjuster, which can finely set the depth accurate to a tenth of a millimetre. Column clamping on both sides also further ensures precise routing results. The extraction bonnet features an LED light ring, ensuring a clean and shadow free working area, while the chip deflector ensures all excess materials are safely caught. Cutter replacement and tool-free copying ring changes make this 1/2” router convenient to use and the quick-acting break make it a safe choice. The OF 1400 EBQ-Plus also boasts Festool’s MMC power electronics with constant adjustable speed and temperature monitoring for work on all types of material.
Supplied with 1/4 and 1/2 collets, extraction bonnet with light module, side fence with fine adjuster, copying ring, chip deflector, collet spanner, 30mm guide bush, T-LOC SYSTAINER® SYS3 M 337 stacking storage case.
Collets Supplied 1/4 and 1/2
Rating Trade/Professional
Spindle Lock Standard Feature
Sound Power Level LwA [Uncertainty K] 93 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 82 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 3.5 m/s² [2.0 m/s²]
Motor Power 1,400 W
Cutter Speed 10,000 - 22,500 rpm
Manufacturer Part Number 574345 & 574344
Voltage 230 V
Web Attribute Set Routers
EAN Barcode 4014549151259
