PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
23.9% APR (variable)
Purchase interest rate
23.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
Lamello products are renowned for their precision and quality, saving you time and money with outstanding results. Our knowledgeable and friendly team are available to demonstrate the Lamello range in person or via a video call. You can see the tools in use and ask questions before placing your order.
The TOP21 features a height adjustable blade for greater precision. This has to be the ultimate in biscuit jointing from the inventors of the biscuit jointer Lamello. Precise in every way, it is very easy to set cutter and fences for exact placement on your work. The cutter can be adjusted for height as well as having 6 preset depth settings. The fences on the TOP21 are flush on the sides for easier positioning; the angle stop/extending front fence is for mitre joints 0-90° with indents 22.5°, 45°, 67.5°and 90°, the square fence stop is used for stability and runs parallel, locking squarely with a quick lever. The soft start 800W electronic motor has no fall off in speed irrespective of the load, the plunge action is extremely smooth and the blade has scoring teeth for the cleanest cutting action. Overall this has to be the ultimate jointer available today. Supplied with, dust bag, dust extraction connectors (23 and 36mm), 4mm slip-on plate, tool kit and Systainer case.
Enquire - contact us for a personalised quote
Electronic motor control for soft start and no fall off in speed irrespective of the load
Height adjustment plus or minus 2.0mm x 0.1mm
Ability to adjust to exact centre of workpiece
Fences with flush sides and precision square locking
Extending front fence with indents at 22.5°, 45°, 67.5° and 90°
Square fence for extra stability on certain cuts
Blade with scoring teeth for clean and precise cuts
Efficient dust extraction through base
Supplied with dust bag, 2 x hose connectors, fence slip plate & Systainer case
3 years' extended guarantee exclusively on this Lamello Biscuit Joiner. Product must be registered on the Lamello website within 30 days of purchase. Applies to selected countries.
A 2 year warranty applies to all Lamello devices; no registration required.
