Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
The DEROS has to be the most compact random orbit sander on the market today. This model 650CV is supplied with both 125mm and 150mm pads that can be simply swapped over. The body of the machine houses a unique brushless motor with motor control technology. With its small body and low weight of just 1kg, it is perfect for all prolonged use in almost any position - flat, overhead or vertical.
The control and smoothness is excellent with the motor giving constant speed even under load; it is fitted with soft start and electronic brake. You can switch the machine on, then control speed with the variable lever on top of the machine. Speed range covers 4,000 - 10,000rpm and the 350W high performance brushless motor is comparable to a standard 500W motor. The DEROS also features a closed construction so that no dust can enter the machine causing wear. The power cord is exchangeable.
Mirka Abranet® is recommended for use with the machine to produce a flawless finish for a huge range of sanding applications. The 125mm and 150mm backing pads can be exchanged quickly to suit your application; both pads have a universal hole pattern to enable the fitting of many different makes and types of abrasive disc. One of the key features of the Mirka DEROS is the Bluetooth low energy technology, which helps you to reduce your exposure to vibration.
Supplied with 125mm and 150mm pads, 5 x 125mm and 5 x 150mm Abranet® discs mixed grits, pad savers and T-Loc storage case.
2+1 Extended Warranty on Mirka sanders, registration required within 30 days.
Registration is required within 30 days of purchase.
The Mirka 2+1 year warranty applies to Mirka sanders, dust extractors and polishers. If a problem occurs with a Mirka tool caused by a manufacturing defect material or by workmanship; Mirka will repair your tool free of charge in accordance with the warranty terms.
