Axminster Woodturning O'Donnell Dovetail Jaws 3-in-1 Set
718321
From £164.98 £137.48
103 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Saturday 19th Apr
  • The O'Donnell Jaw Package
  • Made exclusively by Axminster in Axminster
  • An extremely versatile set of jaws
  • Enables better access to the workpiece
  • Includes 50mm, 38mm and 25mm jaws
  • Fits all SK100 and SK114 chucks
  • Made from stainless steel to protect against corrosion
  • Axminster SK100 O'Donnell Jaws - 50mm
  • Designed for close-in tool work
  • Deep recess holds long spigots
  • Dovetailed inside and outside on lip
  • 50mm Jaws threaded to accept optional jaw inserts
  • Axminster O'Donnell Jaw inserts - 38mm & 25mm
  • Parallel central bore for gripping a dowel
  • Dovetailed section grips onto a spigot or expands into a recess
  • Enables better access to the workpiece when turning bowls
  • Show More
  1. Axminster Woodturning O'Donnell Dovetail Jaws 3-in-1 Set
Total:
£227.32 £189.43
The O'Donnell Jaw 3 in 1 package comprises a 50mm O’Donnell Dovetail jaw along with both 38mm and 25mm O’Donnell inserts. Made from stainless steel to protect against corrosion, the inserts fit inside the 50mm jaws, each secured with a cap head screw, making fitting and changing simple. The set gives you all three sizes, 25mm, 38mm or 50mm, by simply undoing the screws and sliding the inserts in or out. Supplied as a complete set of three jaw sizes with four hex head cap head screws and a hex wrench. The jaws and inserts are available separately, but there is a price advantage if you buy them all together. Suitable for Clubman and Evolution SK100 and Evolution SK114 chucks only. As with all our dovetail jaws they simply bolt onto the Accessory Mounting Jaws.
Axminster 50mm(2") O’Donnell Jaws
Designed to give access around the jaws for close-in tool work. With a deep recess for holding long spigots and giving rock solid mounting when turning a long way from the headstock without tailstock support. The jaws are also dovetailed both inside and outside on the lip. Nominal external dovetail grip is 50mm. Drilled and threaded to accept additional jaw inserts to convert to smaller jaw diameters.
Axminster O’Donnell Jaw inserts
Two sizes of inserts for use with the 50mm Axminster O'Donnell jaws. The larger set has a parallel grip of 25mm, will close onto a dovetail spigot of 32mm or will open out into a dovetailed recess of 46mm diameter.
The smaller insert set has a parallel grip of 13mm, will close on an 18mm spigot or expand into a 32mm dovetailed recess. The O'Donnell jaws and inserts offer a great range of workholding options enabling better access to the rear of the work piece, especially when turning bowls.
British Made British Made
4.90 103
