2-in-1 Seam Ripper & Stiletto Kit
- Double-ended seam ripper and handy stiletto
- Tools reverse into handle when not in use
- Versatile gift for quilters, hand or machine sewers
A double-ended combination of a seam ripper with a handy stiletto, creating a versatile gift. Anyone quilting, hand or machine sewing will appreciate having this handy tool. It uses the same and interchangeable components from our other sewing project kits. Drill bit required 8mm, recommended bushing set 107861.
Bushing Set Order No. | 107861 |
Difficulty | Intermediate |
Drill Bit Required | 8 mm |
EAN Barcode | 743031896623 |
Minimum Blank Size | 16 mm x 16 mm x 127 mm |
- Standard Delivery* - £4
