Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
3M TR-315+ Versaflo Powered Starter Kit
Code: 103683
  • Easy-to-use, versatile system for respiratory protection
  • Constant airflow, highly efficient filters
  • Fast charging Li-ion battery with charge indicator
  • Electronic audible and visual low airflow and low battery alarms
  • Lightweight turbo system worn on a belt
  • Fits to headtop (not supplied) via a breathing tube
  • Kit contains:
  • TR-302E turbo unit
  • TR-3710E particle filter
  • TR-3600 pre-filter
  • TR-325 standard belt
  • TR-322 high capacity battery
  • TR-341UK battery charger
  • BT-30 self-adjusting breathing tube
  • Air flow indicator
  • Show More
£567.46 (£567.46 Ex. VAT)
Out of stock - dispatch estimate is within 4 weeks.
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (5-7 day) - free
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
The 3M TR-315+ Versaflo system combines performance, protection and functionality with a modern, compact design. It is extremely flexible; you can tailor the system to suit virtually any workplace. This starter kit comprises the component parts to get you up and running. Simply add the headtop you require.
The turbo unit is slim, lightweight and worn on a belt. Fitting to your chosen headtop via a breathing tube, the turbo unit gives a versatile respiratory protective system for environments with hazardous particles. In addition, there are options for nuisance level gas and vapours.
The long life Li-ion battery charges quickly with no memory effect. An electronic audible and visual alarm warns of low battery and/or low airflow for extra safety. The flow rate of 160 litres per minute is constant as the motor compensates for particles collecting in the filter. The run time is 10 to 12 hours depending on the state of the filter.
Please note, this kit contains everything you need with the exception of a headtop, which you need to choose separately.
Depending on the protection level you require, you may need extra filters.
The 3M TR-315+ Versaflo ‘Starter Kit’ comprises TR-302E turbo unit, TR-3600 pre-filter, TR-3710E particulate filter (P), TR-325 standard belt, TR-332 high capacity battery, TR-341UK battery charger kit, BT-30 self-adjusting breathing tube and air flow indicator.
This respiratory protective equipment from 3M has approval to EN12941 class TH2 or TH3 (dependent on the headtop). APF 40 with 3M Versaflo S-Series, M-300 and M-400 head tops, APF 20 with all others.
Specification
Specification
Model TR-315+
Batteries Integral
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
