Achieving the ultimate edge is a process. The process begins with coarse rough shaping and ends with ultra fine polishing. These belts lie towards the end of the process. Their unique makeup speeds up the process. This abrasive can replace multiple stages meaning fewer steps and offer a longer working life. In the long run the belts save time and expenditure.
3M™ Trizact™ Cloth Belt 237AA is a fast cutting aluminium oxide, offering consistent finishes on hard metals such as high carbon and stainless steel. Micron graded aluminium oxide particles form tiny pyramids of abrasive mineral, and evenly coat the X-weight cloth backing. Under medium pressure, these pyramids continually break down to expose fresh sharp mineral, providing a consistent cut and predictable fine finish. The resin bonded abrasive gives greater heat resistance and produces a finer finish.
These belts give faster results and last up to five times longer than conventional abrasive products.
Use Trizact™ to refine your tool’s edge prior to final buffing and polishing.
Unique abrasive speeds up sharpening process
Abrasive can reduce a number of sharpening stages
Offers a long working life up to 5 times longer
3M™ Trizact™ cloth belts can save time and money
Consistent and predictable results
Fast cutting and durable, ideal for high carbon and stainless steels
