Axminster Workshop 8 Piece Matching Plug and Bit Set (15-30mm)
- Accurately matched drills and plug cutters
- Hide screw heads and repair or make decorative plugs
- Cut the plug from an offcut for perfect timber match
- Able to cut plugs up to 50mm in length if required
- Sizes 15, 20, 25 and 30mm
- Neatly packaged in wooden storage case
- Please note: Plug cutters only for use in a pillar drill
This drill and plug cutter set enables you to cut plugs up to 50mm in length and then drill the matching holes to accept them. It would be very useful for all sorts of projects where screw heads need to be hidden or where a contrasting plug of timber or other material could be added as a decorative feature. This set includes the sizes 15, 20, 25 and 30mm.
N.B. Only for use in a pillar drill
EAN Barcode | 5052511037780 |
- Standard Delivery* - Free
