Mirka Abranet Max Abrasive Roll 76mm x 25m
From £65.23 £54.36 was £72.48 £60.40 Save £7.25 £6.04
22 Reviews
  • Long lasting: tough aluminium oxide abrasive
  • Cleaner: net structure allows truly effective dust extraction
  • Saves money: the net backing virtually eliminates clogging
  • Practical: universal product effective on a wide variety of materials.
  • Superior finish: creates a finer scratch pattern resulting in a better surface finish
Abranet Max is a universal product suited to a wide variety of sanding applications. The tough aluminium oxide abrasive grain gives a high cut rate on harder wood types and materials. The backing is a unique net structure that resists clogging. The symmetric net structure enables a more efficient cut and faster stock removal. Sanding requires less pressure resulting in a more consistent surface finish. Abranet Max gives high performance and has a longer lifespan than traditional abrasives, making it a cost effective solution. Designed for dry, light finish sanding by machine or by hand, its true dust-free sanding characteristics result in a cleaner work environment, as well as a better surface finish.
N.B. Please ensure that your dust extraction system is adequate and efficient, dust remaining on the abrasive will shorten it's life and reduce it's performance.
4.20 22
