Earn extra with DOUBLE Points on all purchases!
Amana 2D 3D Spiral Router Cutters With Spektra
- Designed for 2D and 3D CNC profiling and carving
- Cut smooth contours with reduced stepping
- Suitable for small-diameter carving tools
- Can be used with plastic and wood
Crafted specifically for 2D and 3D CNC profiling and carving in plastic and wood using CNC machines, Amana’s high-shear ball nose tips create smooth contours while minimising stepping. With their small diameters, the spiral cutters require careful consideration of material chip-loads. The tools can withstand RPMs up to 60,000, and utilising a directed air blast helps keep chips away while cooling both the tool and workpiece.
The ideal choice for a wide range of applications including 3D carving, precision 2D and 3D carving, deep profiling, dimensional signage, and 3D millwork. Also, designed for model-makers on large 3D milling profiles in abrasive EPS foam and other materials as well as 2D and 3D contouring, profiling, modelling and patten making for cabinetry, sign making, furniture making, and jewellery mould making.
Excellent for cutting:
Acrylonitrile-Butadiene-Styrene (ABS)
Acrylic
Acrylic Stone
Composite
Corian
Coroplast®
Dibond®
Ethafoam
Ethylene-vinyl Acetate Foam (EVA)
Expanded Polypropylene (EPP)
Expanded Polystyrene Foam (EPS)
Extruded Polystyrene Foam (XPS)
Fiberglass
Fiberglass PCB Board
Foam Board
Graphite
High Density Polyethylene (HDPE)
High Density Urethane (HDU)
20lbs High Density Urethane
Lexan™
MDF/HDF
PALFOAM™
Phenolics
Phenolic Composites
Plastics
Poly (methyl methacrylate) (PMMA)
Polyethylene Foam
Polylam
Polyurethane Foam
PVC
PVC Foam Board
Sign Board
Sign Foam
Tooling Board
Wood
XPE (Cross Linked Polyethylene) Foam
With a brilliant distinctively-tinted coloring, the Spektra™ nACo nanocomposite coating provides additional improvements in four critical aspects of router tooling.
nACo coating is a micro-thin ceramic coating which enables the tool's cutting edge to retain crucial sharpness and lubricity. This provides longevity and produces cutting results of the highest quality.
Coating prevents high heat and oxidation which is detrimental to cutting tool performance.
Multi-colored hues, while attractive, will dissipate upon use and yet coating will remain fully effective.
nACo offers approximately 4,500 Vickers for impressive solid hardness on cutting areas of the tool, for an increase up to 2.5 times compared to uncoated bits.
Note: Blue based color dissipates immediately upon use. nACo® nanocomposite coating will not wear off.
Suitable for use with CNC Routers and shouldn't be used with a handheld router.
