Amana 3 Piece Carbide Tipped Vee Groove ACM Router Cutter Set 1/2" Shank
111654
111654
From £110.68 £92.23
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Wednesday 21st May
  • Includes three router bits
  • Carbide tipped v-groove
  • Use with Aluminium Composite Materials (ACM)
This kit is designed for cutting, scoring and shaping Aluminium Composite Materials (ACM) using flat bottom V-grooves. The V-shaped grooves remove the aluminium cover and some polyethylene core, allowing the material to be folded or creased. ACM is widely used in wall panel fabrication, and a range of interior and exterior cladding applications, such as office buildings, hospitals, airports and hotels.
This three piece set is made up of the following carbide tipped v-groove router bits:
90 deg x 0.09" tip width x 1/2 dia x 13/64 x 1/2" shank
108 deg x 0.09" tip width x 1/2 dia x 5/32 x 1/2" shank
135 deg x 0.078" tip width x 3/4 dia x 1/8 x 1/2" shank
These cutters are designed for use in the following materials:
Acetate
Aluminum, Brass, Bronze, Clay, Zinc & Wood Composite Panels
Aluminum 5052
Aluminum Composite Materials (ACM)
Aluminum Composite Panel (ACP)
ALPOLIC® Copper Composite Material (CCM)
Alucobond®
Alupanel®
Bakelite
Dibond®
Durabond
e-panelâ„¢
Etalbond®
Nylon
PE and FR Cores
Phenolics
Plastic/Acrylic
Plexiglas®
PVC
Thermoplastics
Titanium Composite Material (TCM)
Wood
