This set is to produce the appearance of Shaker doors, using CNC technology. It includes the following cutters:
Solid Carbide 4 Cutting Edges Insert Knife 12 x 12 x 1.5mm
Insert V-Groove 60 Deg x 1-1/16 Dia x 29/32 x 1/2 Inch Shank CNC
Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Spiral Plunge 1/8 Dia x 1/2 x 1/4 Inch Shank
Insert Carbide Mini Spoilboard Surfacing, Rabbeting, Flycutter, Slab Leveler & Surface Planer 1-1/4 Dia x 15/32 (12mm) x 1/2 Inch Shank Router Bit
CNC In-Prestaâ„¢ 3 Flute Solid Carbide Cutting Edge Straight Plunge High Production 1/4 Dia x 7/8 x 1/2 Inch Shank
Ideal for producing Shaker doors in MDF or solid panels, this set is suitable for use on all of the following materials:
