Amana 3 Piece Starter Engraving Set
111656
Special Price £215.57 £179.64 was £264.18 £220.15 Save £48.61 £40.51
1 Review
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Friday 11th Jul
  • 3 piece set
  • Designed for sign making and lettering
  • Innovative knife insert design
  • Suitable for wood, MDF, melamine and laminate
This set of industrial V-Groove insert router bits are designed specifically for applications including mitre folds, sign making and lettering. These cutters are innovatively designed with a high grade solid carbide insert knife, which can be rotated as the knife shows signs of wear, to benefit from a new cutting edge. The advantages of using insert tools include: extended tool life, easy replacement of dull knifes, and the use of harder grades of carbide. A secure knife locking system ensures maximum safety and maintains cutting accuracy.
This engraving set includes the following cutters:
CNC Insert V-Groove 45 Deg x 7/8 x 1/2 Inch Shank
Insert V-Groove 60 Deg x 1-1/16 Dia x 29/32 x 1/2 Inch Shank CNC
Insert V-Groove 90 Deg x 3/4 x 1/2 Inch Shank CNC
This set are ideal for cutting the following materials:
Aluminum, Bronze, Copper & Carbon Fiber (Engraving Only)
Foam
Laminate
Melamine
MDF/HDF
Sign Board
Solid Surface
Veneered Plywood
Wood
Xanita® Board*
20lbs High Density Urethane
This set is only for use with a CNC router and shouldn't be used with a handheld router.
5.00 1
