Amana 8 Piece General Purpose CNC Router Cutter Set AMS257 1/4" Shank
111653
111653
Special Price £189.30 £157.75 was £231.98 £193.32 Save £42.68 £35.57
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Friday 18th Jul
  • For signmaking, lettering and engraving
  • Stored in Tanos Systainer
  • 8 piece set
  • Includes Spektraâ„¢ bits
This 8 piece set is designed to excel in signmaking, lettering and engravings, as well as other CNC projects. Provided in a Tanos Systainer with foam insert for secure storage, it's also stackable with other Systainers, making this versatile kit even more useful. This set also includes specialist Spektra™ bits, which feature a nACo® nanocomposite coating for extreme nanohardness and heat resistance.
This comprehensive set includes the following:
In-Tech Insert Carbide V Groove 90 Deg x 11/16 D x 21/64 CH x 1/4 Inch SHK Single Flute Router Bit
Insert V-Groove 60 Deg x 59/64 x 1/4 Inch Shank CNC Router Bit
CNC Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Compression Spiral 1/4 Dia x 7/8 x 1/4 Inch Shank
Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Spiral Plunge 1/4 Dia x 3/4 x 1/4 Inch Shank Up-Cut
Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Spiral Plunge 1/8 Dia x 1/2 x 1/4 Inch Shank
CNC 2D and 3D Carving 5.4 Deg Tapered Angle Ball Tip 1/16 Dia x 1/32 Radius x 1 x 1/4 Shank x 3 Inch Long x 4 Flute Solid Carbide Up-Cut Spiral Spektraâ„¢ Extreme Tool Life Coated Router Bit
Solid Carbide 30 Degree Engraving 0.005 Tip Width x 1/4 Inch Shank Signmaking Spektraâ„¢ Extreme Tool Life Coated Router Bit
Designed for cutting:
Laminate
MDF
Melamine
Plastic/Acrylic
Solid Surface
Wood
Veneered Plywood
With a brilliant distinctively-tinted coloring, the Spektraâ„¢ nACo nanocomposite coating provides additional improvements in four critical aspects of router tooling.
• nACo coating is a micro-thin ceramic coating which enables the tool's cutting edge to retain crucial sharpness and lubricity. This provides longevity and produces cutting results of the highest quality.
• Coating prevents high heat and oxidation which is detrimental to cutting tool performance.
• Multi-colored hues, while attractive, will dissipate upon use and yet coating will remain fully effective.
• nACo offers approximately 4,500 Vickers for impressive solid hardness on cutting areas of the tool, for an increase up to 2.5 times compared to uncoated bits.
Note: Blue based color dissipates immediately upon use. nACo® nanocomposite coating will not wear off.
Suitable for use with CNC Routers and shouldn't be used with a handheld router.
