Amana 90° V Groove Insert Knife 28 x12 x 1.5mm
- Replacement knife insert
- High grade solid carbide
- 90° cutter
Replacement knife insert for V Groove insert router bits. Once the knife insert on your router cutter shows signs of wear, it's easy to replace the insert and your cutter has a brand new cutting edge. Secured with a locking screw system for safety and accuracy.
Suitable for cutting the following materials:
Aluminum, Brass, Bronze, Copper, Gold, Silver & Carbon Fiber (Engraving Only)
Composites
Composite Decking
Foam
Laminate
Melamine
MDF/HDF
Sign Board
Solid Surface
Veneered Plywood
Wood
Xanita® Board
20lbs High Density Urethane
EAN Barcode | 0738685001349 |
- Standard Delivery* - £1.99
