Amana Carbide Insert Spoilboard Router Cutter 1/2" Shank
111587
Special Price £157.80 £131.50 was £193.38 £161.15 Save £35.58 £29.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Friday 11th Jul
  • Spoilboard surfacing and chamfering
  • 4-sided carbide inserts
  • Fast material removal
  • Suitable for MDF and fibreboard
This 3 wing spoilboard cutter is designed for surfacing and chamfering. It's great for planing large surfaces and can remove fine layers of material with ease. It features 3 wings or flutes, each with a 4-sided solid carbide insert knife, which gives maximum cutting efficiency and fast material removal. The higher number of teeth also allows for higher feed rates. The 3 wing design results in a more balanced tool while running and its unique chamfer corner insert design produces a flawless surface.
It is ideal for resurfacing spoilboards and planing large glued up panels using CNC, surfacing and finishing wood using timber slab machines, and rabbeting / slotting. The tool is capable of plunging to a maximum depth of 6mm (1/4") before commencing resurfacing. It is able to remove as little as 0.001" layer of material per pass, if desired.
This cutter is designed for use with the following materials:
MDF
Fiberboard
HDF/LDF
Also able to cut:
Balsa Core
Epoxy (Epoxy Resins)
High Density Urethane (HDU Board)
Plastic/Acrylic*
Plywood/Chipboard
Hardwood/Softwood
Ultra-High-Molecular-Weight Polyethylene (UHMWPE)
* Use lower CNC spindle RPM and adjusted feed-rate to prevent melting and adhesion of the acrylic material to the tool.
Suitable for use with CNC Routers and shouldn't be used with a handheld router. Also suitable for router sled machines. Warning: make sure that your router sled rails are fully stable and squared.
