Amana Compression Spiral Plunge Router Cutters
- Ideal for laminated materials
- Solid carbide
- Clean finish
Amana 8 Piece General Purpose CNC Router Cutter Set AMS174 1/4" ShankFrom £208.18 £173.48
Amana Master CNC Router Cutter Set with Display & 57 CuttersFrom £2,050.98 £1,709.15
These router bits are manufactured in solid carbide for long tool life, even when used in abrasive material. They are ideal for cutting double sided melamine or laminated materials, and produce a clean finish at high feed rates.
These router bits are excellent for cutting the following materials:
Laminate
Laminated Plywood
Melamine
Melamine Particle Board
MDF/HDF
Oriented Strand Board (OSB)
Particle Board
Softwood/Hardwood
Veneered Plywood
Suitable for use with CNC Routers and shouldn't be used with a handheld router.
