Amana Compression Spiral Plunge Router Cutters With Spektra
From £45.11 £37.59 was £55.28 £46.07 Save £10.17 £8.47
1 Review
These router bits are manufactured in solid carbide for long tool life, even when used in abrasive material. They are ideal for cutting double sided melamine or laminated materials, and produce a clean finish at high feed rates.
These router bits are excellent for cutting the following materials:
Laminate
Laminated Plywood
Melamine
Melamine Particle Board
MDF/HDF
Oriented Strand Board (OSB)
Particle Board
Softwood/Hardwood
Veneered Plywood
With a brilliant distinctively-tinted coloring, the Spektraâ„¢ nACo nanocomposite coating provides additional improvements in four critical aspects of router tooling.
• nACo coating is a micro-thin ceramic coating which enables the tool's cutting edge to retain crucial sharpness and lubricity. This provides longevity and produces cutting results of the highest quality.
• Coating prevents high heat and oxidation which is detrimental to cutting tool performance.
• Multi-colored hues, while attractive, will dissipate upon use and yet coating will remain fully effective.
• nACo offers approximately 4,500 Vickers for impressive solid hardness on cutting areas of the tool, for an increase up to 2.5 times compared to uncoated bits.
Note: Blue based color dissipates immediately upon use. nACo® nanocomposite coating will not wear off.
Suitable for use with CNC Routers and shouldn't be used with a handheld router.
5.00 1
