Amana Down Cut Spiral Plunge Router Cutters 1/4" Shank
- High quality carbide
- Ideal for production settings
- Great for dado cuts and grooves
- Particleboard, plywood and laminate
Amana 8 Piece General Purpose CNC Router Cutter Set AMS174 1/4" ShankSpecial Price £169.87 £141.56 was £208.18 £173.48 Save £38.31 £31.92
Amana 4 Piece CNC Simulated MDF Shaker Door SetSpecial Price £100.76 £83.97 was £123.48 £102.90 Save £22.72 £18.93
Amana 3 Piece Starter Engraving SetSpecial Price £215.57 £179.64 was £264.18 £220.15 Save £48.61 £40.51
Amana 8 Piece General Purpose CNC Router Cutter Set AMS134 1/4" ShankSpecial Price £140.90 £117.42 was £172.68 £143.90 Save £31.78 £26.48
Amana 8 Piece General Purpose CNC Router Cutter Set AMS177K 1/4" ShankSpecial Price £142.45 £118.71 was £174.58 £145.48 Save £32.13 £26.77
Amana Master CNC Router Cutter Set with Display & 57 CuttersSpecial Price £1,673.60 £1,394.67 was £2,050.98 £1,709.15 Save £377.38 £314.48
Amana Carbide Insert Spoilboard Router Cutter 1/2" ShankSpecial Price £157.80 £131.50 was £193.38 £161.15 Save £35.58 £29.65
Amana Carbide Tipped Spoilboard Router Cutter 1/4" ShankSpecial Price £22.26 £18.55 was £27.28 £22.73 Save £5.02 £4.18
These spiral-flute bits combine a shearing action for a clean, accurate cut with an augering action for chip clearance. The "down-cut" does as it says and cuts downwards from the surface, providing a clean edge on the material surface. These router bits are manufactured in solid carbide for long tool life, even when used in abrasive material. The polished flutes and razor sharp cutting edges produce superior results.
These bits are primarily for CNC use and are ideal for production settings. They are great for cutting grooves and dado cuts, and are excellent for particleboard, plywood and laminate.
Suitable for CNC routing, handheld routers and router tables.
