These V-Groove insert CNC router bits are specially designed specifically for applications including mitre folds, sign making and lettering. These cutters are innovatively designed with a high grade solid carbide insert knife, which can be rotated as the knife shows signs of wear, to benefit from a new cutting edge. The advantages of using insert tools include: extended tool life, easy replacement of dull knifes, and the use of harder grades of carbide. A secure knife locking system ensures maximum safety and maintains cutting accuracy.
These cutters are excellent for cutting the following materials:
Aluminum, Brass, Bronze, Copper, Gold, Silver & Carbon Fiber (Engraving Only)
MDF
Chipboard
Softwood
Hardwood
Plastic
The 60° cutter can also cut:
Composites
Composite Decking
Epoxy (Epoxy Resins)
Foam
High Density Polyethylene (HDPE)
Laminate
Melamine
PVC
Sign Board
Solid Surface
Veneered Plywood
Xanita® Board
20lbs High Density Urethane
Suitable for use with CNC Routers and shouldn't be used with a handheld router.
