Amana Insert Vee Groove Router Cutters 1/4" Shank
- Designed for sign making and lettering
- Innovative knife insert design
- Suitable for a range of materials
Amana 8 Piece General Purpose CNC Router Cutter Set AMS174 1/4" ShankSpecial Price £169.87 £141.56 was £208.18 £173.48 Save £38.31 £31.92
Amana 4 Piece CNC Simulated MDF Shaker Door SetSpecial Price £100.76 £83.97 was £123.48 £102.90 Save £22.72 £18.93
Amana 3 Piece Starter Engraving SetSpecial Price £215.57 £179.64 was £264.18 £220.15 Save £48.61 £40.51
Amana 8 Piece General Purpose CNC Router Cutter Set AMS134 1/4" ShankSpecial Price £140.90 £117.42 was £172.68 £143.90 Save £31.78 £26.48
Amana 8 Piece General Purpose CNC Router Cutter Set AMS177K 1/4" ShankSpecial Price £142.45 £118.71 was £174.58 £145.48 Save £32.13 £26.77
Amana Master CNC Router Cutter Set with Display & 57 CuttersSpecial Price £1,673.60 £1,394.67 was £2,050.98 £1,709.15 Save £377.38 £314.48
Amana Carbide Insert Spoilboard Router Cutter 1/2" ShankSpecial Price £157.80 £131.50 was £193.38 £161.15 Save £35.58 £29.65
Amana Carbide Tipped Spoilboard Router Cutter 1/4" ShankSpecial Price £22.26 £18.55 was £27.28 £22.73 Save £5.02 £4.18
These V-Groove insert CNC router bits are specially designed specifically for applications including mitre folds, sign making and lettering. These cutters are innovatively designed with a high grade solid carbide insert knife, which can be rotated as the knife shows signs of wear, to benefit from a new cutting edge. The advantages of using insert tools include: extended tool life, easy replacement of dull knifes, and the use of harder grades of carbide. A secure knife locking system ensures maximum safety and maintains cutting accuracy.
These cutters are excellent for cutting the following materials:
Aluminum, Brass, Bronze, Copper, Gold, Silver & Carbon Fiber (Engraving Only)
MDF
Chipboard
Softwood
Hardwood
Plastic
The 60° cutter can also cut:
Composites
Composite Decking
Epoxy (Epoxy Resins)
Foam
High Density Polyethylene (HDPE)
Laminate
Melamine
PVC
Sign Board
Solid Surface
Veneered Plywood
Xanita® Board
20lbs High Density Urethane
Suitable for use with CNC Routers and shouldn't be used with a handheld router.
