Amana Master CNC Router Cutter Set with Display & 57 Cutters
111648
111648
Special Price £1,673.60 £1,394.67 was £2,050.98 £1,709.15 Save £377.38 £314.48
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Available to Order
Delivery
Free Standard Delivery*.
Delivery time is approximately 5 weeks.
  • 57 versatile router bits
  • Presented in solid wood display
  • Use for a variety of applications
  • Bit for cutting most materials
  • High quality CNC router bits
This comprehensive collection of 57 CNC router bits from Amana will virtually guarantee you have a tool for every application. Every bit in this set is manufactured to Amana's stringent high standards for high performance and long tool life. The collection is stored in a solid wood display which can be freestanding or wall mounted, has LED illumination, mirrored interior and locking clear acrylic door.
There is a range of CNC router bits included, across a mixture of tool types, styles and designs, including solid carbide tipped, carbide insert knives, superior "mirror finish" cutting edges, and different material types for different applications. Possible uses include: signmaking, engraving, cabinet making, material surfacing, and more.
This set can be used to cut the following materials:
Aluminum Brass Bronze Copper
Gold Silver & Titanium
Aluminum Composite Material (ACM)
Aluminum FoamCore
Composite
Corrugated Polyproplene
Fiberglass
Fiberglass PCB Board
FoamCore
Gatorfoam®
Graphite
Melamine
MDF/HDF
Laminate
Phenolic Composites
Plastic Acrylic & Plexiglas®
Sign Foam Sign Board & HDU
Solid Surface
Steel and Stainless Steel
Veneered Plywood
Wood
Xanita® Lightboard™ and X-Board™
Please see below for the full list of contents of this impressive kit:
Solid Carbide Single 'O' Flute Plastic Cutting 1/8 Dia x 1/2 x 1/4 Inch Shank
High Precision Steel Router Collet Reducer 1/4 Overall Dia x 1/8 Inner Dia x 1 Inch Long
High Precision Steel Router Collet Reducer 1/2 Overall Dia x 1/4 Inner Dia x 1 Inch Long
High Precision Steel Router Collet Reducer 1/2 Overall Dia x 3/8 Inner Dia x 1-3/16 Long
Solid Carbide Carving Liner 18 Deg x 1/4 Dia x 5/8 x 1/4 Inch Shank x 1-Flute
Solid Carbide CNC Foam Cutting Up-Cut Square End Spiral 1/8 Dia x 1-1/8 x 1/4 Shank x 2-1/2 Inch Long Router Bit
Solid Carbide CNC Foam Up-Cut Cutting Square End Spiral 1/4 Dia x 2-1/4 x 1/4 Shank x 2-1/2 Inch Long Router Bit
Solid Carbide Up-Cut Spiral Ball Nose 3/32 Radius x 3/16 Dia x 1/2 x 1/4 Shank x 2-1/2 Inch Long x 2 Flute Router Bit
Solid Carbide Up-Cut Spiral Ball Nose 1/8 Radius x 1/4 Dia x 1/2 x 1/4 Shank x 2-1/2 Inch Long x 2 Flute Router Bit
CNC Solid Carbide Spiral for Steel & Stainless Steel with AlTiN Coating 3-Flute x 1/8 Dia x 3/8 x 1/4 Shank x 1-1/2 Inch Long Up-Cut Router Bit / 45º Corner Chamfer End Mill
CNC Compression Solid Carbide ZrN Coated Honeycomb Cutting 3/8 Dia x 1-1/4 x 3/8 Shank x 6-Flute
CNC In-Groove Insert Engraving Tool Body 1/4 Inch Shank
CNC Solid Carbide ZrN Coated Honeycomb Cutting Hogger 1/4 Dia x 1-1/4 x 1/4 Shank x 4 Inch Long x 6-Flute
1/2 Inch Shank CNC Extension Adapter for 1/4 Inch Shank Router Bits
CNC Variable Helix Spiral Square Bottom 1/4 Dia x 5/8 x 1/4 Shank Solid Carbide AlTiN Coated End Mill
Solid Carbide CNC Spektraâ„¢ Extreme Tool Life Coated Spiral 'O' Flute, Plastic Cutting 1/8 Dia x 1/2 x 1/8 Shank Up-Cut Design Router Bit
Solid Carbide CNC Spektraâ„¢ Extreme Tool Life Coated Spiral 'O' Single Flute, Plastic Cutting 3/16 Dia x 5/8 x 1/4 Shank x 2 Inch Long Up-Cut Router Bit
Solid Carbide CNC Spektraâ„¢ Extreme Tool Life Coated Spiral 'O' Flute, Plastic Cutting 1/4 Dia x 3/4 x 1/4 Inch Shank Up-Cut Router Bit
CNC Insert V-Groove 45 Deg x 7/8 x 1/2 Inch Shank
Insert V-Groove 60 Deg x 1-1/16 Dia x 29/32 x 1/2 Inch Shank CNC
Insert V-Groove 90 Deg x 3/4 x 1/2 Inch Shank CNC
CNC Solid Carbide Spiral for Steel & Stainless Steel with AlTiN Coating 3-Flute x 1/4 Dia x 5/8 x 1/4 Shank x 2-3/8 Inch Long Up-Cut Router Bit / 45º Corner Chamfer End Mill
Solid Carbide Insert 30 Deg x 0.005 Inch V Tip Width Engraving Knife for In-Groove System
Carbide Tipped Double Edge Folding V-Groove 90 Deg x 0.090 Inch Tip Width x 1/2 Dia x 13/64 x 1/4 Inch Shank
Carbide Tipped Double Edge Folding V-Groove 108 Deg x 0.090 Inch Tip Width x 5/32 x 1/2 Dia. x 1/4 Inch Shank
CNC Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Compression Spiral 3/8 Dia x 1-1/4 Inch x 3/8 Shank
CNC Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Compression Spiral 1/2 Dia x 1-1/4 x 1/2 Inch Shank
CNC Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Compression Spiral 1/4 Dia x 7/8 x 1/4 Inch Shank
Solid Carbide CNC Spektraâ„¢ Extreme Tool Life Coated Spiral 'O' Flute, Plastic Cutting 1/8 Dia x 1/2 x 1/4 Shank Up-Cut Design Router Bit
Solid Carbide CNC Spektraâ„¢ Extreme Tool Life Coated Spiral 'O' Flute, Plastic Cutting 1/4 Dia x 1 x 1/4 Inch Shank Up-Cut Router Bit
Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Spiral Plunge 1/4 Dia x 3/4 x 1/4 Inch Shank Up-Cut
Solid Carbide V-Groove 60 Deg x 1/4 Dia x 7/32 x 1/4 Inch Shank
Solid Carbide Spiral Plunge with Corner Radius 1/16 Radius x 1/4 Dia x 3/4 x 1/4 Inch Shank Up-Cut
CNC 2D and 3D Carving 0.10 Deg Straight Angle Ball Tip 1/4 Dia x 1/8 Radius x 1-1/2 x 1/4 Shank x 3 Inch Long x 2 Flute Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Router Bit
CNC Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Compression Spiral 1/8 Dia x 13/16 Inch x 1/8 Shank
CNC 2D and 3D Carving 3.6 Deg Tapered Angle Ball Tip 1/8 Dia x 1/16 Radius x 1 x 1/4 Shank x 3 Inch Long x 3 Flute Solid Carbide Up-Cut Spiral Spektraâ„¢ Extreme Tool Life Coated Router Bit
Solid Carbide CNC Spektraâ„¢ Extreme Tool Life Coated Spiral 'O' Flute, Plastic Cutting 1/4 Dia x 3/4 x 1/4 Inch Shank Down-Cut Router Bit
CNC 2D and 3D Carving 6.2 Deg Tapered Angle Ball Tip x 1/32 Dia x 1/64 Radius x 1 x 1/4 Shank x 3 Inch Long x 3 Flute Solid Carbide Up-Cut Spiral Spektraâ„¢ Extreme Tool Life Coated Router Bit
CNC 2D and 3D Carving 5.4 Deg Tapered Angle Ball Tip 1/16 Dia x 1/32 Radius x 1 x 1/4 Shank x 3 Inch Long x 4 Flute Solid Carbide Up-Cut Spiral Spektraâ„¢ Extreme Tool Life Coated Router Bit
CNC 2D and 3D Carving 1 Deg Tapered Angle Ball Tip x 1/8 Dia x 1/16 Radius x 1-1/2 x 1/4 Shank x 3 Inch Long x 3 Flute Solid Carbide Up-Cut Spiral Spektraâ„¢ Extreme Tool Life Coated Router Bit
Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Up-Cut Ball Nose Spiral 1/8 Radius x 1/4 Dia x 1 Inch x 1/4 Shank Router Bit
Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Up-Cut Ball Nose Spiral 1/4 Radius x 1/2 Dia x 1-1/4 Inch x 1/2 Shank Router Bit
CNC 2D and 3D Carving Flat Bottom 0.10 Deg Angle x 1/8 Dia x 1-3/32 x 1/4 Shank x 2-1/2 Inch Long x 4 Flute Solid Carbide Up-Cut Spiral Spektraâ„¢ Extreme Tool Life Coated Router Bit
Solid Carbide Up-Cut Spiral 1/4 Dia x 3/4 x 1/4 Shank x 2-1/2 Inch Long Composite, Fiberglass & Phenolic Cutting Spektraâ„¢ Extreme Tool Life Coated Router Bit
Solid Carbide CNC Spiral 'O' Flute, Aluminum Cutting 1/8 Dia x 5/16 x 1/8 Shank Up-Cut ZrN Coated Router Bit
Solid Carbide CNC Spiral 'O' Flute, Aluminum Cutting 1/8 Dia x 1/4 x 1/4 Shank Up-Cut ZrN Coated Router Bit
Solid Carbide CNC Spiral 'O' Flute, Aluminum Cutting 1/8 Dia x 1/2 x 1/4 Shank Up-Cut ZrN Coated Router Bit
Solid Carbide CNC Spiral 'O' Flute, Aluminum Cutting 3/16 Dia x 1/2 x 1/4 Shank Up-Cut ZrN Coated Router Bit
Solid Carbide CNC Spiral 'O' Flute, Aluminum Cutting 1/4 Dia x 5/8 x 1/4 Shank Up-Cut ZrN Coated Router Bit
Solid Carbide CNC Spiral 'O' Flute, Aluminum Cutting 1/4 Dia x 5/8 x 1/4 Shank Down-Cut ZrN Coated Router Bit
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
