Amana Solid Carbide Vee Groove Router Cutters 1/4" Shank
From £22.60 £18.83 was £27.68 £23.07 Save £5.08 £4.23
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Cut V-grooves and lettering
  • Spektra™ nanocomposite coating
  • Produce chamfers and bevel edges
  • Suitable for range of materials
These router cutters from Amana are designed to cut decorate V-grooves and lettering, perfect for sign making. With an edge guide, you can use them to chamfer and cut bevel edges.
The 30° 0.005 tip is for extra-fine carving and lettering, and can cut wood, plastic and solide surface materials. The maximum RPM is 28,000.
These router bits are excellent for cutting the following materials:
20lbs High Density Urethane
Acrylic
Composites
Composite Decking
Foam
Laminate
MDF/HDF
Melamine
Plywood
PVC Plastic
Sign Board
Solid Surface
Veneered Plywood
Wood
Xanita® Board
With a brilliant distinctively-tinted coloring, the Spektra™ nACo nanocomposite coating provides additional improvements in four critical aspects of router tooling.
• nACo coating is a micro-thin ceramic coating which enables the tool's cutting edge to retain crucial sharpness and lubricity. This provides longevity and produces cutting results of the highest quality.
• Coating prevents high heat and oxidation which is detrimental to cutting tool performance.
• Multi-colored hues, while attractive, will dissipate upon use and yet coating will remain fully effective.
• nACo offers approximately 4,500 Vickers for impressive solid hardness on cutting areas of the tool, for an increase up to 2.5 times compared to uncoated bits.
Note: Blue based color dissipates immediately upon use. nACo® nanocomposite coating will not wear off.
Suitable for use with CNC Routers, handheld routers and router tables.
