Amana Spiral Down Cut Aluminum Cutting Router Cutter ZrN Coated
111628
111628
Special Price £30.18 £25.15 was £36.98 £30.82 Save £6.80 £5.67
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 15th Jul
  • Zirconium Nitride (ZrN) Coating
  • Spiral 'O' flute
  • Suitable for a range of materials
  • "Mirror finish" cutting edge
This spiral 'O' flute router bit is ideal for industrial applications and is manufactured to produce optimum results on every cut, and should help make aluminium projects less labor-intensive. Made from the highest quality sub-micrograin carbide, it features a polished "mirror finish" cutting edge. This means a cleaner cut, reduced risk of chip re-welding, superior surface finish, and extended tool life. Right hand helix right hand cut.
This router bit can be used to cut the following materials:
ALPOLIC® Copper Composite
Material (CCM)
Alucobond®
Aluminum
Aluminum 5052
Aluminum 6061
Aluminum Alloys
Aluminum Composite
Materials (ACM)
Aluminum Composite Panel (ACP)
Alupanel®
Brass
Copper
Dibond®
Durabond
e-panelâ„¢
Etalbond®
Fomex® with Aluminum Face
Gold
Non-Ferrous Metals
Plastic
Silver
Solid Surface
Titanium Composite Material (TCM)
Wood
This cutter features a Zirconium Nitride (ZrN) coating, which offers these benefits:
• A harder and tougher cutting edge, leading to increased life of the cutting edge and reduced build up in the flutes during cutting.
• Increased spinning rate compared to an uncoated tool.
• A low Total Indicated Runout (TIR) and optimized flute geometry: resulting in clean cuts and reduced chatter under high chip loads, and virtually eliminate sanding.
• High flute volume supporting high feed rates and chip loads.
• High aspect ratio for single pass deep-reach cutting.
Suitable for use with CNC Routers and shouldn't be used with a handheld router. Do not cut ferrous metals with these bits. It's recommended to use mist lubricant system or air cooling for best results and extended tool life. Maximum RPM: 35,000.
