Amana Spiral Upcut Aluminum Cutting Router Cutters
- Spiral 'O' flute
- Highest quality carbide
- Suitable for a range of materials
- "Mirror finish" cutting edge
Amana 8 Piece General Purpose CNC Router Cutter Set AMS174 1/4" ShankSpecial Price £169.87 £141.56 was £208.18 £173.48 Save £38.31 £31.92
Amana 4 Piece CNC Simulated MDF Shaker Door SetSpecial Price £100.76 £83.97 was £123.48 £102.90 Save £22.72 £18.93
Amana 3 Piece Starter Engraving SetSpecial Price £215.57 £179.64 was £264.18 £220.15 Save £48.61 £40.51
Amana 8 Piece General Purpose CNC Router Cutter Set AMS134 1/4" ShankSpecial Price £140.90 £117.42 was £172.68 £143.90 Save £31.78 £26.48
Amana 8 Piece General Purpose CNC Router Cutter Set AMS177K 1/4" ShankSpecial Price £142.45 £118.71 was £174.58 £145.48 Save £32.13 £26.77
Amana Master CNC Router Cutter Set with Display & 57 CuttersSpecial Price £1,673.60 £1,394.67 was £2,050.98 £1,709.15 Save £377.38 £314.48
Amana Carbide Insert Spoilboard Router Cutter 1/2" ShankSpecial Price £157.80 £131.50 was £193.38 £161.15 Save £35.58 £29.65
Amana Carbide Tipped Spoilboard Router Cutter 1/4" ShankSpecial Price £22.26 £18.55 was £27.28 £22.73 Save £5.02 £4.18
These spiral 'O' flute router bits are ideal for industrial applications and are manufactured to produce optimum results on every cut, and should help make aluminium projects less labor-intensive. Made from the highest quality sub-micrograin carbide, they feature a polished "mirror finish" cutting edge. This means a cleaner cut, reduced risk of chip re-welding, superior surface finish, and extended tool life. Right hand helix right hand cut.
These router bits can be used to cut the following materials:
ALPOLIC® Copper Composite
Material (CCM)
Alucobond®
Aluminum
Aluminum 5052
Aluminum 6061
Aluminum Alloys
Aluminum Composite
Materials (ACM)
Aluminum Composite Panel (ACP)
Alupanel®
Brass
Copper
Dibond®
Durabond
e-panelâ„¢
Etalbond®
Fomex® with Aluminum Face
Gold
Non-Ferrous Metals
Plastic
Silver
Solid Surface
Titanium Composite Material (TCM)
Wood
Suitable for use with CNC Routers and shouldn't be used with a handheld router. Do not cut ferrous metals with these bits. It's recommended to use mist lubricant system or air cooling for best results and extended tool life.
