Arbortech Abrasive Discs 100mm (Pkt 12) - Mixed
- Pack of 12 assorted 100mm sanding discs
- Easy change hook and loop backing
- 3 each; 60, 120, 180 and , 240 grit
A pack of 12 assorted 100mm diameter sanding discs to suit the Arbortech Power Carving Unit. The discs feature hook and loop backing for quick abrasive change, allowing you to reuse partially worn discs. The pack comprises 3 of each grit 60, 120, 180 and 240.
Abrasive Backing | Hook and loop |
Abrasive Disc Diameter | 100 mm |
Abrasive Grit | Mixed |
EAN Barcode | 9313478902426 |
- Standard Delivery* - £4
