The Arbortech Mini TURBO Plane Kit is a revolution in wood sculpting. This unique tool is designed to fit the Arbortech Power Carving Unit and most 100mm or 115mm angle grinders using the supplied extension adaptor.
The blade is precision machined from high quality steel and fitted with 2 tungsten carbide teeth. The cutting teeth are rotatable, resharpenable and replaceable but it may be some time before replacements are required.
This unique tool is great to use freehand or with guides and templates for accurate repeatable shaping. The comprehensive kit includes the Mini TURBO blade, extension adaptor, 3 assorted sanding discs, a rubber backing pad, M5 fixing screws and washers plus torx and hex drive keys.
Web Attribute Set Power Carving Accessories
EAN Barcode 9313478320022
