Arbortech Power Carving Range
For over three decades, Arbortech have been at the forefront of power carving innovation
Embracing new ideas and challenging the norm, they design, develop and manufacture some of the most unique cutting tools! Explore the range of tools and attachments below to broaden your power carver's capabilities.
Choose a tool to see what you can create with the attachments
Mini Carver
Power Carving Unit
Power Chisel
Power Chisel
Arbortech Mini Carver
The robust and compact design allows you to undergo tasks such as rough shaping, wood cutting, sculpting, shaping and more!
Optional attachments:
  • Mini Industrial Blade
  • Mini Pro Blade
Perfect for freehand power carving; gives you great performance even on tough hardwoods.
Find out more
Mini Pro Blade
Find out more
Arbortech Power Carving Unit
Get the best results every time you carve and experience power carving like never before with the ultimate power carving unit.
  • Mini TURBO Plane Kit
  • Industrial Woodcarver Blade
  • TURBO Shaft
  • Contour Sander
  • TURBO Plane Blade
  • Ball Gouge
  • Sanding Pad
Carve convex and concave shapes freehand and enjoy a smooth finish that requires minimal sanding.
Find out more
Use to tackle the hardest of timbers, even when it includes dirt and other debris.
Find out more
TURBO Shaft
A versatile addition to any woodworker's arsenal; perfect for detailed freehand sculpting and template work.
Find out more
Contour Sander
Achieve exceptionally smooth surfaces.
Find out more
TURBO Plane Blade
Rapidly shape, sculpt and plane a huge variety of flat and curved parts.
Find out more
Ball Gouge
Create smooth concave shapes and add chiselled features to your projects.
Find out more
Sanding Pad
Perfect for sanding medium to large projects and capable of moulding to slight contours.
Find out more
Arbortech Power Chisel
The free hand power carving tool that comes with a dedicated Arbortech Grinder motor. It does everything a traditional hammer and chisel will, only easier and faster.
Included attachments:
  • 7 chisels in a pouch for detailed carving, chiselling, lettering and adding texture
Arbortech Precision Carving System
The Arbortech Precision Carving System is designed for free form carving, sculpting, detailing and texturing.
  • Precision Universal Base
  • Precision Ball Gouge
  • Precision Barrel Carver
  • Precision Drum Sander
  • 2 x sanding grits for Precision Drum Sander (60 grit and 120 grit)
  • 2 x Allen Keys
