Get the best results every time you carve and experience power carving like never before with the ultimate power carving unit.
Arbortech Woodcarving Tools
Introducing the new Arbortech Power Carving Unit, the ideal power source for all your Arbortech attachments! Simply secure any Arbortech attachment to the unit and experience optimal power carving performance!
The Power Carving Unit comes with a chip catcher, levelling guide, sanding pad, fan and chip tube.
As an alternative to an 'off the shelf' angle grinder, the Power Carving Unit, designed by the R&D department at Arbortech, helps you get the most out of any Arbortech attachment. Specifically created to optimise all the Arbortech accessories, it ensures you can achieve the best results. It is a highly versatile tool, the variable speed allows you to use it for carving, planing and sanding.
Ergonomics combine with safety features providing comfort and control. The Power Carving Unit is compact, lightweight and fitted with an anti-vibration handle. It has a soft start avoiding abrupt jolts when switched on. Additionally, the safety lock-on switch prevents accidental restarts.
The chip catcher acts as a guard and allows direct connection to a vacuum to get rid of almost all dust and wood chips. The levelling guide is perfect to create levelled surfaces on timber, refurbish old timber and strip thin layers of paint using the sanding pad or Arbortech TURBO Plane. The sanding pad is a soft 100mm backing pad with edges specifically designed to better conform to a curved, carved surface. It’s the perfect tool to finish the shaping process and removal of tool marks. The fan and chip tube deflect the majority of the wood chips when using the TURBO Plane, without the need for a vacuum.
Get the most out of any Arbortech attachment
Created for woodcarving, planing and sanding
Great versatility from variable speed control
Ergonomic design provides comfort and control
Fitted with an anti-vibration handle and soft start
The Power Carving Unit comes with a chip catcher, levelling guide, sanding pad and fan and chip tube
