The Arbortech Power Chisel is a freehand power-carving tool that enables you to carry out detailed carving and controlled chiselling as well as rapid waste removal. Built around the dedicated Arbortech grinder motor, it does everything a traditional mallet and chisel will do, only easier and faster.
The Power Chisel is extremely easy and safe to use. The chisel only engages and starts to move when pressed onto the timber; the reciprocating action is less than 1mm. The high frequency movement of the chisel results in very smooth, flowing, controllable and continuous carving. Depth as well as direction of carving is easy to control with high precision and perfect visibility. Quick-change technology means you can change chisel at the click of a button.
With low vibration and a long working life, this is a great tool for detailed carving, chiselling, lettering and adding texture to carvings.
This package includes a complete set of 7 chisels in a chisel pouch, as well as special lubrication oil and spare felt.
Detail carving and chiselling with precise control
Great for texturing and lettering
Powerful, smooth reciprocating action
Activated when pressed onto workpiece
11,000 strokes/min allows rapid waste removal
710W motor for carving even the hardest woods
Extended head for all round visibility and easy access
Push button for easy, tool free chisel changing
Supplied with 7 chisels, storage pouch, special lubricant and spare felt pad
We use cookies to improve and personalise our services, for marketing and for social activity. Please see our
privacy policy for more information on how and why we use your data. You can change your
cookie settings at any time. By continuing, you agree to our
use of cookies.
