Arbortech Abrasive Discs 100mm (Pkt 8)
- Packs of 8 sanding discs
- 100mm diameter
- Easy change hook and loop backing
A packs 100mm diameter sanding discs to suit the Arbortech Power Carving Unit. The discs feature hook and loop backing for quick abrasive change, allowing you to reuse partially worn discs. Each pack contains 8 discs; choose from 60, 120, 180 or 240 grit.
Abrasive Backing | Hook and loop |
Abrasive Disc Diameter | 100 mm |
