Arbortech SpheroPlane
112887
From £275.00 £229.17
  4. Half Star
3 Reviews
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 15th Jul
  • Ideal for creating wooden bowls or spheres
  • Seamlessly transitions from carving to sanding
  • Features an adjustable carving radius for versatile projects
  • Made with rotatable and replaceable tungsten carbide teeth
  • Provides precise and clean cuts with minimal dust
  • Compatible with Arbortech Power Carving Unit™ and standard angle grinders
Power up with super Sphero strength!
Enjoy lathe-like functionality and the freedom to create anywhere with the superior cutting action of the SpheroPlane®
Create convex and concave shapes
Perfect for creating beautifully shaped wooden bowls and spheres with ease.
Precision adjustable carving radius
Carve as much or as little as you like by simply adjusting the fine-tuning collar.
Patented cutting action
Effortlessly switch between carving and sanding with the omni-directional guiding base.
Safety and control
Full surround guarding system significantly reduces kickback and provides exceptional balance and control.
Cleaner working
Dust and chip extraction provides a cleaner working experience and easier clean-up.
Engineered to last
Features durable, rotatable, and replaceable tungsten carbide teeth for long-lasting performance.
Versatile compatibility
Best used with the Arbortech Power Carving Unit, but also compatible with any standard 115mm (4 1/2") or 125mm (5") angle grinder.
  1. Arbortech SpheroPlane
Total:
£675.00 £562.50
The Arbortech SpheroPlane® is a powerful tool designed for woodworkers who want to create wooden bowls or spheres without the need for a lathe. This innovative tool simply attaches to an angle grinder and allows you to carve with precision and ease.
The SpheroPlane® features a precision adjustable carving radius, allowing you to fine-tune the size with the adjustable collar. Its patented cutting action provides smooth and even cuts with omni-directional guidance. The included Sanding System allows a seamless transition from carving to sanding with the flexible sanding pad and discs (40, 80, 120, and 240 grit), making it easy to turn rough wood into a polished pieces. Add a dust extraction vacuum for a cleaner working experience and easier clean-up.
Engineered to last, the SpheroPlane® is built with precision machined billet aluminium and cutting-edge engineered plastic for durability and wear-resistance. Rotatable and replaceable tungsten carbide teeth ensure unmatched performance and longevity. The full surround guarding system provides precise exposure settings, reducing kickback and offering exceptional control.
Compatible with the Arbortech Power Carving Unit™ and any standard 115mm (4 1/2") or 125mm (5") angle grinder.
3.70 3
