Robust steel construction riveter with interchangeable screw-in nose pieces for the full range of rivet sizes. The arms with their powerful lever action have comfortable moulded grips and the head is extended for better access into tight corners. A first rate tool for the professional workshop.
Arrow
Arrow RH200 Professional Riveter
| Model | RH200 |
| Max Rivet Diameter | 4.8 mm |
