This bearing guided ogee cutter comes with one bearing. It is useful for making decorative edges, furniture plinths, cornices. This single cutter offers four options, either a plain ogee, or with a top fillet for greater definition. Changing to the smaller bearing adds the options of a bottom fillet or fillets top and bottom. A bearing ensures an even depth of cut and allows you to undertake curved work.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
Supplied with 1 bearing
Ideal for decorative edges, furniture plinths, cornices
Larger bearing for ogee, with or without a top fillet
Smaller bearing for bottom fillet or fillets top and bottom
Bearing ensures an even depth of cut
Allows use on curved work pieces
High shear-cut angle for cleaner finish
Thick PTFE coating helps cutter to remain free of resin
