This round nose cutter has a top bearing for following a template. The bearing is the same diameter as the cutter, greatly simplifying template making. This cutter produces a round-bottom grooves in cabinet doors or on drawer fronts. It adds attractive detail such a fluting. Use a suitable template for routing recesses or lettering.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up. 6.35mm radius.
Produce round bottom grooves on doors and drawers
Use to make decorative flutes
Top bearing for following a template
Use with template for lettering
Precision made on multi axis CNC machines
High shear-cut angle for cleaner finish
PTFE coating helps cutter to remain free of resinp
