Axcaliber Bearing Guided Vee Groove Cutter
- Especially suited for working with templates
- Ideal for lettering projects
- Use for simple vee grooving
- Precision made on multi axis CNC machines
- PTFE coating helps cutter to remain free of resin
- 1/4" shank
A very useful 1/4" shank cutter, especially suited for working with templates. Numerous applications can be carried out, including chamfering, lettering and vee grooving.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
D = Overall Diameter | 12.7 mm (1/2") |
EAN Barcode | 5052511029211 |
K = Cutter Angle | 45° |
X = Depth of Cut | 12.7 mm (1/2") |
- Standard Delivery* - £1.99
