This carving and shaping blade will give excellent results when used on a 115mm angle grinder (22mm bore). Being a little heavier than similar products and well balanced with five tungsten carbide cutting tips, the blade is very smooth in use with a controllable cutting action. The blade is 100mm diameter and the cutting tips are 6.8mm wide with a rounded profile. If you need to remove a lot of material quickly when carving or sculpting this blade will take some beating. N.B. It is important that protective equipment and adequate guarding should be used when using this type of blade.
We use cookies to improve and personalise our services, for marketing and for social activity. Please see our
privacy policy for more information on how and why we use your data. You can change your
cookie settings at any time. By continuing, you agree to our
use of cookies.
