Axcaliber Contract 165mm TCT Saw Blades
- Generously sized tips brazed onto tensioned quality steel plates
- 165mm
- 1.5mm kerf
- 20mm bore
- Perfect for cordless circular saws
The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price. Manufactured in one of the most advanced facilities in the world, they are produced to the highest standards using the finest materials available. With the range covering everything from hand held power tools right up to large panel saws used in production workshops, you will be certain to find a blade to suit every requirement. These 165mm blades are for hand held circular saws and have a thin kerf for lower power requirements. 20mm bore.
Blade Diameter | 165 mm |
Bore Size | 20 mm |
Kerf | 1.5 mm |
Maximum RPM | 7,000 rpm |
Plate Thickness | 1.0 mm |
Tooth Format | ATB |
