Axcaliber Contract 254mm Saw Blades Pack Of 3
- Generously sized tips brazed onto tensioned quality steel plates
- Rip cut blade (24 teeth)
- General purpose (40 teeth)
- Fine cross cut (80 teeth)
- 3.2mm kerf
- 30mm bore all blades
Trend Tool and Bit Cleaner - 532mlSpecial Price £14.78 £12.32 was £16.78 £13.98 Save £2.00 £1.67
Axcaliber Contract saw blades give you unrivalled cutting performance at a realistic price. This package of 3 x 254mm blades ensures you will always have the right blade for the job to hand. The package comprises a 24-tooth rip blade, a 40-tooth general purpose and an 80-tooth fine finish crosscut blade.
The tensioned, ground plates with laser cut arbor holes and anti-vibration slots ensure smooth running. Their fine, micro grain TCT tips are accurately brazed onto the plate with a CNC welding machine before being automatically ground to a razor sharp edge.
Bore size 30mm. A range of bore reducing bushes is available.
Blade Diameter | 254 mm |
Bore Size | 30 mm |
EAN Barcode | 5052511120116 |
Kerf | 3.2 mm |
Maximum RPM | 7,600 rpm |
Plate Thickness | 2.2 mm |
- Standard Delivery* - Free
