Axcaliber Contract 315mm TCT Saw Blades
- Generously sized TCT tips brazed onto tensioned quality steel plates
- Rip (28 teeth, 3.2mm kerf)
- General purpose (48 teeth, 3.2mm kerf)
- Combination (60 teeth, 3.2mm kerf)
- Cross Cut (72 teeth, 3.2mm kerf)
- 30mm bore
The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price.
Manufactured in one of the most advanced facilities in the world, they are produced to the highest standards using the finest materials available. With the range covering everything from hand held power tools right up to large panel saws used in production workshops, you will be certain to find a blade to suit every requirement. Bore size 30mm. A range of bore reducing bushes is available. A great choice for a panel saw.
Blade Diameter | 315 mm |
Bore Size | 30 mm |
Kerf | 3.2 mm |
Maximum RPM | 6,000 rpm |
Plate Thickness | 2.2 mm |
