Axcaliber Cutter for Axcaliber Dovetail Jigs (13-19mm Material)
- Cutter for Axcaliber, Axminster and Perform dovetail jigs
- Suitable for material thickness 13 to 19mm
- Precision made on multi axis CNC machines
- PTFE coating helps cutter to remain free of resin
- 1/4" shank
Trend Tool and Bit Cleaner - 532mlSpecial Price £14.78 £12.32 was £16.78 £13.98 Save £2.00 £1.67
This is a replacement cutter for the Axcaliber, Axminster and Perform dovetail jigs and best suited for a material thickness of approx 13-19mm. Produced using advanced technology on up-to-the-minute multi axis CNC machinery. Shanks made from SAE4140 steel hardened to Rockwell 45 HRC, renowned for its hardness and strength, and the tips are made from diamond ground micrograin tungsten carbide.
D = Overall Diameter | 15 mm |
EAN Barcode | 5052511029181 |
K = Cutter Angle | 14° |
X = Depth of Cut | 11.5 mm (29/64") |
- Standard Delivery* - £1.99
