Axcaliber Dish Carving Cutter
- Bottom cut with a curved radius
- Good choice for producing trays or dishes
- Extremely versatile, rout bowls, lettering etc
- Use a template and guide bush for production work
- Precision made on multi axis CNC machines
- PTFE coating helps cutter to remain free of resin
- 1/4" shank
A bottom cut with a nicely curved radius makes this cutter a good choice for producing trays or dishes. As an extremely versatile cutter, it is ideally suited to routing bowls, lettering, trays including jewellery and cutlery trays as well as other finely crafted projects. For use with a template, a suitable guide bush should be used.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
D = Overall Diameter | 25.4 mm (1") |
EAN Barcode | 5052511029174 |
R = Radius | 6.35 mm (1/4") |
X = Depth of Cut | 12.7 mm (1/2") |
- Standard Delivery* - £1.99
