Axminster Dovetail Jig
- Simple to set up and use
- Heavy gauge steel pressings
- Steel clamp bars and handles
- 6mm thick aluminium guide template
- Comprehensive instruction manual
- Bearing guided dovetail cutter included
- 275mm board width capacity
- Takes material 15 to 35mm thick
This dovetail jig is designed to produce beautiful, tight dovetail joints that match on all four corners.
Produce precise dovetail joints
Fitted with the cutter supplied (for 13-19mm material), the jig can be used to cut both lap and rebated lap dovetails for basic drawer construction.
Achieve more with optional accessories
Produce 1/2" strong, precise comb or finger joints with an optional bearing guided straight cutter. Or opt for the optional fine finger comb to produce 1/4" half blind dovetails.
Large board capacity
Accepts workpieces up to 275mm wide and from 15mm to 32mm in thickness.
Minimal assembly required
Extremely simple to set up and use, the jig comes complete with a comprehensive instruction manual.
Axcaliber Cutter for Axcaliber Dovetail Jigs (19-30mm Material)From £11.18 £9.32 -
Simple to set up and use, the Axminster Dovetail Jig is very robustly made from heavy gauge steel pressings. Fitted with cam action clamps, the workpieces are held quickly and securely while the smooth anodised finish on the 6mm thick machined finger template ensures that both parts of the joint are cut accurately and cleanly. Full instructions are supplied along with a quality bearing guided dovetail cutter. The jig can be used with any router with a base diameter not exceeding 160mm that will take 1/4" shank cutters, (although lightweight models are most suitable). Fitted with the cutter supplied (for 13-19mm material), the jig can be used to cut both lap and rebated lap dovetails for basic drawer construction or fitted with an optional bearing guided straight cutter, it will also produce 1/2" strong, precise comb or finger joints for tool boxes and utility furniture. Using the optional fine finger comb, the jig can be used to produce 1/4" half blind dovetails for spice drawers and jewellery boxes. Material capacity 275mm width 15 - 32mm thickness.
| Dovetail Size | 15 mm |
| EAN Barcode | 5052511054282 |
| Material Thickness | 15 mm to 32 mm |
| Material Width | 275 mm |
| Model | DTJ |
- Standard Delivery* - Free
