Axcaliber FineLine Pull Saw 17tpi - 240mm
- Diamond-ground, impulse hardened teeth with 3 cutting edges
- Cuts on the pull stroke for better control
- Pistol grip handle with rubberised comfort grip
Technologically advanced diamond ground teeth; each with three razor sharp cutting edges for an ultra smooth finish with a fast cutting action. These saws cut on the pull stroke, the blades are fitted with pistol grip handles securely fixed with screws. The handles all feature a rubberised comfort grip. The Japanese style teeth are impulse hardened for long life. Used for cutting wood, chipboard, pvc, plasterboard. With wood, these saws are excellent for crosscut or mitre work.
EAN Barcode | 5052511005239 |
Length of Blade | 240 mm |
Tooth Pitch \ tpi | 1.50 mm \ 17 tpi |
- Standard Delivery* - £1.99
