Axcaliber Freshcut 37 GT Straight Cut Bandsaw Blades
- Unique diamond precision ground teeth for an exceptionally clean, thin kerf cut
- Perfect for rip cuts in all types of timber, less power required than normal
- Light tooth set reduces waste, hook tooth configuration for maximum penetration
- Ground teeth retain their edge far longer than normal blades
- Manufactured in Axminster using advanced CNC welding techniques
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price £69.97 £58.31 was £89.98 £74.98 Save £20.01 £16.67
The Freshcut 37 GT Straight Cut bandsaw blade range is made from bright carbon steel stock sourced in the Midlands. The teeth are precisely diamond ground, before going through a hardening process, then annealed for flexibility and finally the stock straightened by a machine process. This produces a super sharp, hard tooth, with the benefits of a long cutting life and a smooth, quiet cut. The teeth have a light set which gives a narrow kerf and reduces the waste produced whilst the hook configuration provides maximum penetration. These blades are perfect for ripping all types of timber, producing veneers and boards, the ground teeth retaining their edge far longer than normal milled tooth blades. A unique bandsaw concept, and totally British made.
